Irrigation pump help
   / Irrigation pump help #1
bigtalker
Gainesville, GA. Sandersville, GA
I have a berkley 2hp 3stage pump that I use to irrigate with pumping from lake. It has started cutting off after about 5 minutes run time , staying off about 15 minutes then cutting back on for 5 minutes. The motor seems unusually hot and the Id plate says the motor has thermal overload protection. I have been running it about 4 1/2 hours every other day with no problem . Can anyone offer any advice. Thanks very much.. Greg B
   / Irrigation pump help #2
Check for a plugged suction / foot valve.
Has the pump ever been run dry ?
If so you will need to rebuild it.
You should not cycle it on overload, it will burn the overload switch out.
E/S
   / Irrigation pump help #3
You might want to check the voltage while running,, You might only have one leg running.. You want to do this as close to the pump as possable incase your wire has a break in it somewhere,,
WACKER NEUSON EZ36 EXCAVATOR (A52705)
WACKER NEUSON EZ36...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55301)
GALAXY - SET OF...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
SCAN FOR HAULING AND FINANCING INFORMATION (A54757)
SCAN FOR HAULING...
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
