Hello everyone. I have had my 2003 Ironhorse 284 (Y385 engine) for almost 3 years now. It has 320-ish hours on it and all works pretty well. The problem I have had since last winter is starting in anything cooler than 40 degrees F. Warmer than that, its starts just fine every time, in terms of starter drive engagement. When its colder than that during initial start, the starter drive will just spin (and not engage), until I release the key from the start position. At that point, it makes a horrible grinding noise as it slows down and engages with the flywheel. I have taken the starter drive apart and cleaned it spotless and only coated the starter drive shaft with a graphite spray, during reassembly. After engine runs a bit (and warms up starter assembly) it starts as normal every time after. This only occurs when the starter is initially cold.
I dont want to replace a working starter unless I have to. Does anyone have any suggestions or ideas before I buy a whole new starter??
Thanks in advance!
Thanks in advance!
