Inverting the front rims for more stability
   / Inverting the front rims for more stability #1
Jer
So. California
Two tractors..both Mitsubishi. MT160D 4WD with a Brush Cutter. The other is a MT1601 4WD with a loader
I just purchased a MT1601D 4WD with a loader. Can I invert the front rims which would increase the distance between the front tires giving me more stability when using the loader??
Jerry S.
   / Inverting the front rims for more stability #2
Most people recommend not because it puts extra strain on the front end parts.
Eugene
   / Inverting the front rims for more stability #3
I have a 4x4 and I inverted the front wheels for more stability. No problems yet. You can always change them back.
   / Inverting the front rims for more stability #4
Making the front wider does not do much if anything. The axle is on a pivot. A rear wheel will be off the ground a long way before a wider front would come into play. The 4x4 will help going down a hill with a load helps a load because the rear can lose traction and you cannot stop.
UNUSED HURRICANE MSC2020F ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
2025 Mower King SSEFGC175 (A50123)
2025 Mower King...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
