Inverter welders??
   / Inverter welders?? #1
Steve C
Platinum Member
North Central Michigan
Farm Pro 2425
The last time I was in the Harbor freight store I noticed that they had a couple of very small "inverter welders" for sale. They were very small, only about the size of a shoe box. The description states that it does all kinds of good things. :confused::confused:
I have never seen these before. Does anyone know if these are stand alone units or are the designed to be used as an add on to an existing welder?:confused::confused:
   / Inverter welders?? #2
I think they are small stand alone 110volt welders good for lighter stuff and for use in remote areas. They use digital circuitry instead of big heavy transformers to do the job. I have not used one but have seen them a lot, this is the same tech that is making small plasma units that seem to be pretty good which I have used them...
I think they require a little different style of welding than the old style stick welders.
mark
   / Inverter welders?? #3
They are awesome little welders they work excellent. I have also used their full sized units that put out 500 Amps and only weigh 75lbs. The arc characteristic is better than most generated machines. Plus it doesn't use as much current as the other machines all in all an excellent system.
   / Inverter welders?? #4
Inverters are the best not only do they offer great size, they give great DC characteristics, better arc starting and a smooth arc. Most of them you can set up for TIG as well.
As far as welding "style" they are scratch or lift start, and they are stand alone units. All the high end TIG and MIG units are inverter technology, they draw less amperage.
I have a 100 amp Air Liquide Inverter and I throw it on a Rhino with a generator and run up and down my neighbours fence line fixing his elk fence.
I think harbor freight is a lot like Canada's Princess Auto and that would be my only concern is the quality, so use your discretion.
   / Inverter welders?? #5
I have a miller max star 150 inverter welder it is great! service factor must be monitored.
I'm not sure about the HF stuff.
I had one tig job that paid for it the only regret that I didn't get the remote for it but it can still be added if needed.
tom
   / Inverter welders?? #6
I like inverters and have put in many hours using one, but don't actually own one myself.
For steady output it's the only thing that comes close to an old motor-generator welder, especially when you have a "dirty" electrical supply.
A bonus with the inverters compared to the motor-generator sets is they don't have the noise or weight. I've done a fair bit of stainless and aluminum TIG as well as stick with a Miller Dynasty; a very nice machine.
I've used two models of the small Miller inverters. One did stick and DC TIG while the other did just stick. I haven't used an inverter welder that I didn't like and wouldn't hesitate to buy one if the need arose.
Like it was suggested above, I'm inclined to stick with big names. Hunt for specials and don't be afraid to haggle!
Here's neat idea:
On one job we were running a Trailblazer 302 doing stick with 3/32" 7018. To speed things up, we grabbed the small Miller inverter we had and ran it off the auxiliary power; instant dual operator rig. It worked nicely with the small rods required for that job, but I'm not sure about running larger electrodes with that setup.
   / Inverter welders?? #7
Caveat emptor. Yes inverter power supplies are very efferent. On a welding site, the HF welders have very poor reputations, particularly the Mig's., some could not weld there way out of a paper bag. If you do purchase one, check out HF's return policy and keep the sales receipt.
   / Inverter welders?? #8
Basically they get DC in two stages;
1) a "chopper" power supply from 50 or 60 cycles and simple rectifier to produce a "rough" DC
2) An "inverter" (OK, an oscillator) to produce a higher frequency AC that is also rectified to produce the welding DC.
More complex than the buzz boxes, but the savings are in copper and iron, which translates to less weight, size and cost.
It is POSSIBLE to produce a smoother DC from the higher frequency second stage AC, since the ripple can be taken out for less $s.
300 amp inverter welders are now quite common and in general use, the BIG NAMES also offer them.
As with tractors, it isn't clear who actually makes what or who imports and re-badges what.
Thanks for the information. I have always aproached the purchase of Harbor Freight tools with the expectation that "you get what you pay for". For the most part they haven't failed to live up to/or down to that expectation.:confused::confused:
I have been pleasantly suprised with the $2 digital VOM's, I have a half dozen of them around here. The cables are a little cheasy but I expect that in a $2 meter. They sure aren't equal to a $100 Fluke, but they seem servicible for what I need one for.
I had not seen the term "inverter welder" before. I haven't shopped for a welder in about 30 years. I seem to recall that way back when they offered add on inverter boxes for doing tig work.:cool:
Now that I know what they are I will have to keep on the look out for a small name brand unit. My 295 amp buzz box and my 250 amp ac/dc are not very portable. I was impressed by the shoe box size and light weight of the little inverters.:D:D:D:D:D:D:D:D
   / Inverter welders?? #10
Steve, check out WeldingWeb.com, scroll down to, Manufacture Product Forums---Harbor Freight.
Check out the post by smyrna5, he has a video of what your 80 amp welder. See and learn.:eek:
2019 Ford Transit Cargo Van (A51694)
2019 Ford Transit...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
100 GAL FUEL TANK W/PUMP TOOLBOX COMBO (A53843)
100 GAL FUEL TANK...
