Invasive Software
   / Invasive Software #1
BB_TX
Veteran Member
Home-1+ acres New Hope, TX / 24 acres-Fannin Count
JD 950
This may prevent you some grief. /forums/images/graemlins/mad.gif
<font color="blue"> MSNBC Story </font>
It also provides a link to free download software to combat the invasive software. The free software seems to have been researched by credible sources to verify that it in itself is not just more trash. Haven't tried it yet, but plan to.
   / Invasive Software #2
Here's a simple policy I have to avoid such problems.
1) I don't download anything from anyone I don't know.
2) I don't download anything from someone I do know unless it's something they originated (not something they got from someone else).
3) I don't download anything from anyone unless I'm expecting it.
4) I don't download anything I am expecting until I've confirmed that what I'm about to download is, in fact, what they sent and meets the above criteria.
It is simple enough to do and it works.
   / Invasive Software #3
Good suggestions. These will help too.
Make sure your email program is NOT set to open attachments automatically.
Don't open any email attachment unless you KNOW by its file extension type that it is not any sort of executable file--i.e., jpg, gif, png are OK. Just because it's not an exe doesn't mean it's not executable.
Or use something other than Windows for an operating system.
SnowRidge
   / Invasive Software #4
I run spybot on all of our computers once a week.
   / Invasive Software #5
</font><font color="blue" class="small">( Just because it's not an exe doesn't mean it's not executable....)</font>
Exactly - Most Microsoft Office applications have macro (small executable program) capabilities. But worse - Microsoft Access Database (.mdb extension) files can be SELF executing. Microsoft itself recognizes this and its Outlook e-mail application will not accept Access Database (.mdb) file attachments because of the danger.
Generally, my rule is if I don't recognize the sender, I delete the e-mail without opening it whether it has an attachment or not.
On a similar note - I never return calls to phone numbers I get on my pager unless I recognize them. There are scams there too that will cost you big time for just dialing the number.
   / Invasive Software #6
Here's something I always do just to be safe.
Use Windows Explorer's Search feature to find a file called wscript.exe. It will be in your Windows\System32 folder I believe.
Right click on the filename and select Rename. Name the file wscript_.exe or something similar.
This is the program Outlook uses to execute attachments. If it cannot find it, there is no way for it to execute anything from your mailbox. This eliminates the possiblity of inadventently running something you know you shouldn't.
I got this tip from a coworker of my wife's who has to keep 140 computers running. They still get "not a nice word" people running stuff explicitly and infecting their network periodically, but this trick helped a lot.
   / Invasive Software #7
I use netscape, not so many holes and not so much stuff targeting it. I use common sense as outlined above and have no problems.
   / Invasive Software #8
Wscript.exe is actually the Windows Script Host. It is used to run Visual Basic and Java scripts on your machine. Unlikely to be used on a home PC and is probably a good idea to rename.
1067 (A53342)
1067 (A53342)
2001  WABASH 53FT DRY VAN TRAILER (A54607)
2001 WABASH 53FT...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
2012 JCB 930 ROUGH TERRAIN FORKLIFT (A52705)
2012 JCB 930 ROUGH...
