tb8100
I can't tell you how excited I am about these things. VERY VERY well-designed.
What's coming out first? The all-electric MTV. Not like a golf car or anything like that. We're talking BALLSY and well-built machines. Check 'em out:
Yes, it's a mid-sized UTV, an RUV. It has a trailing-arm rear suspension (so a solid axle), 48V electric, ballsy, tops out at 25mph, 1000# bed capacity, electric bed lift standard, selectable 4wd, and I believe this will even fit in a short bed truck. It will debut in black and orange, as you can see, and there should also be a camo pattern (not an official pattern like Mossy Oak, but nice anyway). Set to hit stores in January 2009 with an estimated price tag of $8999 for the base model.
Also available in a crew cab version:
The front has two bucket seats and the back has a full bench. I kindof wish they had a full bench in the front, but you really don't need a kid in the front anyway. The crew unit will have a beefier electric motor to compensate for the increased load and weight. I believe this model should be $10,000 or a little over.
There was also a prototype gas model that should debut a few months after the electric MTV:
Another shot:
Note the unusually long bed. Bed height is about like a Polaris Ranger, right below chest level for grabbing stuff. Also note all the fender space for oversized tires.
Check out the underside of this bad boy:
It's like a tank!!
It is hydraulically driven with a variable displacement pump and a hi/lo range, and they're toying with rear remotes:
I'm hoping they'll take advantage of the remotes for a rear 3 point option, and offer front hydraulics for a loader and other attachments. There is hydrostatic power steering and a hydraulic dump standard on here.
This machine was the ultimate Bad Boy, but it didn't get near the attention the electric ones did, mainly because we all got to drive the electric ones, not this one.
The power plant for this super bad machine:
Yes sir. The 35hp BIG BLOCK Vanguard!!!
Price point: $11,000-$11,500. This machine goes up against the Kubota RTV as being the only other traditional UTV that is hydraulically driven, though the Kubota has a hydrostatic transmission. Oh, and if you don't like the jerkiness of a hydro when you let off on the pedal, no problem. There is an adjustable coast valve (an omission that is Kubota's Achilles heel!!). I wonder when Bad Boy is bringing in the CAT diesels!!
If you weren't able to tell from the specs, the target market for this machine is landowners, hence the low top speed and the build style. The electric machines are awesome for hunters though. Zero emissions and little noise.
EDIT: I totally forgot one of the biggest things about these machines. The suspension is unreal. We carry the Husqvarna HUVs, and I've driven Polarises, Gators, RTVs, Rhinos, just about everything out there, and nothing drives as smooth as these do over bumps. We're not talking about a barely noticeable difference. We're talking you can be driving these along and drive over a parking stone without even slowing down and you are not even jolted. They're literally that smooth.
Sorry about the crappy phone pix. I will get better pix up as soon as I get a hold of them.
More information as it becomes available!!
Another shot:
It's like a tank!!
