CliffordK
Veteran Member
- Joined
- Mar 8, 2013
- Messages
- 2,113
- Location
- Eugene, Oregon
- Tractor
- Toro D200, Ford 1715, International 884,
Ok,
I picked up a used International 47 Baler.
I'm still testing it. Some of the feeder gears/chainrings were in bad shape, but hopefully I'm getting those straightened out.
However, with my test baling, every few knots, I hear a WHAM, and I break a shear pin.
There seems to be a stop under the carriage, I presume to protect the needles & etc. Anyway, it is located about 6" before the knives. At the point everything stops, the needles have moved forward, say 3" or so. No enough to penetrate the hay, I don't think, but just enough to trigger the stop.
To get running again, I replace the shear pin, turn the flywheel backwards slightly, pull the needles back towards the resting position and fire it up again.
The knots aren't perfect, but I seem to be getting good enough of bales when the shear pin does't break. So, what do I have to adjust to ****** the timing of the knoters/needles slightly?
I suppose I could also disable the stop, but obviously it is there to protect my needles from being busted if something major fails.
What I'm thinking is the needles/knotters seem to be adjusted OK, but they are being triggered a moment too early.
