International Cub won't start
   / International Cub won't start #1
OrtisEvans
Bronze Member
Laytonsville, MD
Ford NAA, Farnall Cub, Kubota B2100
I last ran it last fall and it worked fine. I tried to start it in January and no-go. The carb was flooding so I cleaned it an put in a new needle and seat. I checked the spark, which was weak, so I put in points, rotor, condenser, and cap. Still no go even with ether. I thought that I may have put in the distributor out of phase, so I checked it and that is fine. I checked compression and that is good. I thought maybe stink bugs had gotten in the exhaust and clogged it so I disconnected the pipe at the manifold. No help. Today, I pulled the plugs, laid them on the head with the wires connected and cranked to check spark. All are good. I checked timing again by putting a thumb on the #1 spark plug port, and yes, the spark occurred about when my thumb was pushed off. (I assume that the #1 cylinder is at the engine front - nearest the radiator, right?).
I am out of ideas. Suggestions?
Ortis
I'm impressed - my post has 26 views but no answers! Either the answer is so obvious that everyone is laughing, or the problem is impossible. EIther way, I am in trouble!
   / International Cub won't start #3
Yes, # 1 is at the front.
Did you get your wires back on in proper order? Rotation should be CW.
Even though you tried it on ether, did you check for fuel on the plugs?
With wires out 180コ, it would probably fire on exhaust anyway... POW..!!
This is a distributor, and not a magneto?
Hand cranking, or starter?
With proper timing, spark, and fuel, it should at least pop...
How far do you have the throttle set? If you do not have it set a little higher to run, than the starter is cranking it over, it may not start.
I have had better luck putting a little gas in the cylinder (half-dozen drops or so), directly in the cylinder. Maybe a couple of them...
   / International Cub won't start #4
Ortis
I have a 1948 Cub that I'm working on--rebuilding the distributor/magneto.
You need fuel, air and spark to get that beasty running--you have the spark so it's got to be one or both of the other factors. I'd recheck your carb--if it's timed correctly and you're getting spark, it could be the carb--clogged jet would be my guess. To eliminate another fractor, I'd disconnect the air filter line to the carb and try to run it that way.
   / International Cub won't start #5
1, I would NEVER pull the dizzy to repalce points.. it's asking for trouble.
if it sat a long time.. might be stuck rings.. put some atf down the holes and let it set.. then roll it over the next day to expell the oil.. try again with start fluid.... once you get it started.. work it.
post back.
soundguy
Thanks for the ideas.
I am using the starter to crank it, and I do have the throttle wide open. Since I was using ether, have alwaysfound that having the trottle open gets the ether in better -especially since I am not relying on the carb when using ether.
I did have try disconnecting the air cleaner - no help.
I agree with Soundguy that pulling the distributor is not a great idea. The Cub does not give you much room to work, and I have pulled it several times and been fine. Since I have compression, I was thinking I don't have stuck rings, but a little atf can't hurt.
This tractor does not have a mag.
I'll also try a little gas in each cylinder - can't hurt.
I gotten a lot of engines working over the years, and I know that if you have fuel, spark, and compression they have to run - unless of course you have screwed something up - which has happened once or twice. I'll let you know what happens.
   / International Cub won't start #7
Hook another tractor to the cub and pull start it in 3rd gear. If its got compression/spark and fuel, sooner or later, it will heat itself up enough to fire...and you won't be ruining the starter or the battery to do it....BobG in VA
   / International Cub won't start #8
You also may want to check that your float didn't stick in the carb after the rebuild. Sometimes a little tap on the side gets it to drop and work. Have had this happen before.
   / International Cub won't start #9
try another set of plugs,have had plugs short to the cylinder head through cracks in the insulator thus killing spark when installed but test ok when checking for spark.When you tried ether did the engine fire but not start or was there no response ,if spark was good it should have fired with ether and if it didnt i would say the issue still remains with spark or compression.If it did fire on ether then fuel would be the most likely fault .Also check that all the engine valves are opening and closing and not stuck .Have just read about a Farmall B on the farmall forum with spark issues where the condenser and /or wiring was shorting in the distributor,this would give a weak spark or no spark
Hope this may help
Update - I tried ATF in the cylinders. After purging, I tried again - I got a few nice puffs of black exhaust from the ATF (actually, I didn't have ATF and used hydraulic fluid). So, I will replace pugs on general principles, but now I am betting on some valve issue. Next step: pull the manifold and valve cover to see what is happening there.
Thanks for all the ideas.
On spark plugs - I have seen plugs where they are fould to where the spark jumps thru the ceramic right to the shell, but these are sparking right where the should be - even when covered in haydraulic fluid!
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2021 Ford F550 XL 4x4 Service Truck (A52384)
2021 Ford F550 XL...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2014 Ford F-350 Western Mule 2,000 LB 1 Ton Crane Service Truck (A51692)
2014 Ford F-350...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
Sany SY35U Pro Mini Excavator (A52384)
Sany SY35U Pro...
