JesseB414
Hello All!
I have recently acquired an international B414 tractor early 70s late 60s, the unit runs great however I am having an issue with the clutch remaining slightly engaged when I step on the pedal but only when there is a load on against the tires. At first when I bought the unit I had trouble with the PTO not disengaging with the second stage of the clutch. This proved to be the clutch pedal had come loose from the connecting rod that goes into the clutch housing. I have had the inspection cover off and sprayed some penetrating oil on the bearings in hopes it would assist with the clutch disengaging from the transmission but no such luck. The gap is set correctly on the clutch, and the pedal is also correct. To best describe what is happening is if I am not preforming any work and just need to change gears I can push the clutch in and change gears no issues, however if I am plowing with the bucket, snow blowing, or scooping with the bucket when I push the clutch in the tractor does not fully disengage and still moves very slowly but enough that the brakes will stop it, the only way I can then change gears is by killing the engine going to neutral and then restart and go on my way. Does anyone have any ideas what I can check or am I in for a clutch rebuild? The previous owner has had no issues with it and I used it for 3 months without any either until the clutch adjustment but the way I see it by making that adjustment I would have made the clutch disengage more if anything.
