International B 414 Diesel Wont Start - Need Help
   / International B 414 Diesel Wont Start - Need Help #1
OldDawg
Warner Robins, Ga
1963 International B414
Hey Guys,
I am new to the forum, but have been reading posts here for years to help with issues, so thanks in advance for past help.
I have a 64 B-414 Diesel that wont start. It was running great but I ran it out of fuel two weeks ago. Here is every detail of what was done while it was down.
1- We replaced the #22 oring from the injector diagram on the throttle arm. (it was leaking and upon removal, there wasn't one there)
It is still leaking slightly.
2 - The starter was dragging bad and was saturated (inside) with fuel (Leaking oring above) so I bought an new aftermarket starter with the solenoid on the starter itself. The old solenoid was mounted on the firewall. This starter doesn't have a need for the "engage lever" that you have to push down on the old starter, so that is bypassed. My buddy wired the starter and it turns great, but the two wires that were on the pressure switch from the old starter are just wired together? I know that switch had some involvement with the starter, but as I said, the new starter turns great. My concern - will any of the old starter wiring interfere with the engine starting as long as the starter is turning good? Most of the wiring on the tractor is cut and hard to trace, but I don't know for sure if there is a circuit that would prevent the tractor from firing?
3 - We bled the fuel beginning at the pump, all the way through the sequence from the manual and feel that it is purged of air. Seem to be getting good fuel flow to the injector pump and also some fuel at the injectors (however on this tractor I don't know how to tell if it is sufficient)
Tractor has new fuel, new starter, has been bled good, but will not start (even with a shot of ether).
I have purchased the glow plug conversion kit that I have seen posted on the forum, but haven't installed that yet, just need to get her running again first.
   / International B 414 Diesel Wont Start - Need Help #2
:welcome:
To the forum. I am sure that someone here will be able to help. Are you connected with the base?
Thanks for the welcome. I think everyone in WR is connected to Robins somehow, but no, not directly. I have a lot of Air Force friends however.
   / International B 414 Diesel Wont Start - Need Help #4
If the only thing you actually changed from the old setup is the solenoid and the wiring at the starter pedal, start there.
Starter is spinning so the new solenoid appears to be working, only thing left is the starter pedal switch.
You need to find out how the switched worked originally and how it is working now since you eliminated it.
Check the web for a schematic on the starter system and trace that wire.
These are obvious things hope you just over looked something.
Thanks guys for the replies. Harry nailed my issue. It was indeed just the o-ring. My buddy installed the o-ring in the position that looked obvious in the parts fiche, but I took it off today and she started in the first turn. Thanks to all and I'm looking forward to more discussions and help.
   / International B 414 Diesel Wont Start - Need Help #6
Olddawg I have the same model of tractor. I love it
   / International B 414 Diesel Wont Start - Need Help #7
Did you bleed the lines to the injectors as well?
   / International B 414 Diesel Wont Start - Need Help #8
No I havnt had any issues with it. Works very well
   / International B 414 Diesel Wont Start - Need Help #9
I had a few issues with air getting into my lines, took a couple of the injectors apart and cleaned them well and haven't had an issue since.
2020 KUBOTA RTV...
FRONTIER LR5060 LOT NUMBER 148 (A53084)
FRONTIER LR5060...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2014 Freightliner M2 106 Medium Duty Truck with Tool Bed, VIN # 1FVACWDT0EHFS2811 (A51572)
2014 Freightliner...
2011 Liebherr L586 (A53472)
2011 Liebherr L586...
2006 FORD F-250 (A52472)
2006 FORD F-250...
