International 584
   / International 584 #1
pontiacman
I have a recently acquired 584, and am having a tough time with the 3 pt. It did not have lift arms on it when I traded for it, so I found some salvage pieces and put the 3pt back on. I hooked up the PHD and it is either all up or all down, depending on the position of the draft control. (light the PHD raises fully up, Heavy it drops immediately.) If set on heavy draft, I can lift the PHD with the position lever, but it will fall immediately when the lever is released. the only way to try hold a steady position is to make VERY slight adjustments on the draft control.
Any advice is greatly appreciated.
Thanks,
Scott
2015 CATERPILLAR 930M WHEEL LOADER (A52706)
2015 CATERPILLAR...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
(NEW) 2022 Greenworks CU400W Commercial Work Utility Vehicle (A55302)
(NEW) 2022...
2017 Kenworth T370 Service Truck with Crane, VIN # 2NKHHJ7XXHM175924 (A54865)
2017 Kenworth T370...
2011 Ford F450 Diesel with Just 156638 Miles (A55302)
2011 Ford F450...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
