international 424 valve settings
   / international 424 valve settings #1
winston1
Super Member
gilmer tx
Bobcat CT235
I am getting desperate! I have requested the valve settings on two different International forums but have got no feedback. Hoping one of you Yanmar owners might also own a manual or have knowledge of the valve settings on an old 424 gas engine International. I have googled and found one sight saying maybe .014" on both intake and exhaust while hot. Can anyone confirm or deny that being correct? Thanks for hearing and hope I don't anger anyone by posting in the Yanmar forum. Just hate to buy a manual for one piece of information.
   / international 424 valve settings #3
I cannot confirm or deny for you; the manual I have for the IH 454, 464, 574, and 674 all call for 0.027 inches for both valves while hot.
Apparently the engine in your 424 is a longer stroked version of the C-135 motor; I see several places calling out for 0.014" hot for that smaller engine, but there might be a serial number break where the clearances go to 0.020" on the exhaust.
"Yeah, the C-135 over some 34,xxx serial number had a .020 exhaust clearance." From: Farmall Cub
My two cents: It's better to have too much clearance than not enough. I wouldn't go any tighter than 0.014", and if it's looser, I wouldn't worry about it.
The procedure in my IH manual numbers the cylinders from 1 to 4, starting at the front of the engine, away from the flywheel. They number the valves 1 through 8 in sequential order. Their recommended procedure is to set cylinder 1 at TDC, and adjust valves 1 ,2, 3, and 5. Then rotate the engine one revolution so cylinder 4 is at TDC, and adjust valves 4, 6, 7, and 8.
I wish I had better information for you. Good luck!
   / international 424 valve settings #4
Thanks guys. I purchased the on line manual Normde recommended. .014" on intake, .020" on exhaust, with engine warm. Manual is well worth $10 although the tractor is just passing through my garage on the way to a new home. She is purring like a kitten. :thumbsup:
   / international 424 valve settings #6
My thoughts exactly.
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2016 Ford F-150 Crew Cab Pickup Truck (A49461)
2016 Ford F-150...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
2017 FREIGHTLINER M2 BOX TRUCK (A51222)
2017 FREIGHTLINER...
Payment Terms (MUST READ) (A50775)
Payment Terms...
