International 1086 water in oil
   / International 1086 water in oil #1
oklahomafarmer
Harrah, Oklahoma
John deere 4430, 4440 & International 1086
I have a 1086 that was sitting for about 4-6 years but it had a recent overhaul (less than 100 hours). I ran it for probably 20+ hours. I replaced the valve cover gasket and put a new turbo on it and when I started it up after about 30 minutes oil/water mixture was coming out of the blow by tube. I have taken the pan off and pressurized the radiator and cannot find a leak there. So I'm assuming it is not a liner with a hole in it. Anyone know what it could be or what else to check?
Any info would be greatly appreciated! Thanks
   / International 1086 water in oil #2
When my John Deere M was overhauled, it had water in the oil shortly after. The friend who did the work told me to tighten the head because water was leaking by the gasket. I tightened it and the leak stopped.
Update: it has sat for a few days now with the cooling system pressurized and it hasn't dropped below 10 psi. Has a small leak on one fitting is why it dropped from 20-10 within about 1.5 days
   / International 1086 water in oil #6
Let's start out with the simple stuff! Could it be just moisture from condensation from freezing to warmth? to leave the tractor sit for a period of 24 hours slowly remove the drain plug and see what comes first! If it is just water and it has antifreeze in it the it is just condensation and don't worry, go run it! To have antifreeze come out then you have issues!
It would be rare for it to be an oil cooler as oil pressure is normally higher then any radiator cap pressure!!! That means you would have oil in the cooling system!!!!
Year: 2002 Make: Ford Model: Econoline Vehicle Type: Van Mileage: 156,145 Plate: Body Type: 3 Door (A51694)
Year: 2002 Make...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A53426)
2019 INTERNATIONAL...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
2025 IR UNUSED Cleanout Bucket (A53117)
2025 IR UNUSED...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
