kemartin3
Bronze Member
I'm interested in how folks with tractors in the 30-40HP range are providing hydraulics to their backhoes. Mine is a Kubota L3710 which is spec'd at 7.8GPM. The hoe I'm looking at is a Woods BH80-X which is supposed to need 5-7GPM. At first glance it would seem like using the internal hydraulics (tap into the circuit on the side of the 3 pt case where Kubota does to feed their auxiliary valves) would work fine. But the dealers I've talked to hem and haw, and don't really want to commit on an opinion. I'm going to call Woods to get their input, but nothing beats empirical evidence from folks who have actually done it. If you can tell me why you made the decision you did and what model tractor/hoe you have, then I can match up the flow rates for your combinations and see how they compare to mine. I'd sure like to not have to buy that $1000 pump assembly if I don't need to. I'm not doing commercial work, so it doesn't need to be lightening fast.
As always, thanks for all of the good information!
