scott_vt
Super Member
- Joined
- Oct 5, 2004
- Messages
- 7,429
- Location
- east wells,vt
- Tractor
- 1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
1942 Farmall A : Prognosis wont run, will turn over...
Check the basics, gas, spark, compression all OK
Gas was getting old from none use, drain tank, fresh gas, still wont run
Saprk plugs old, may as well put new ones in, still wont run
Check points, pull top of mag off and clean points and regap, still wont fire
That last operation turned into my undoing, because I accidently got my timing 360 degs off
The funs not over yet !
Check spark again, seems weak and intermittent !
Battery is weak and cables are kind of shot, so new battery and cables ouch
Still wont start !
Carb starts pissing gas all over the garage floor, no problem, take the carb off the Super A. Still wont start
Then it finally dawns on me what I may have donr initially checking the points
Yep sure enough 360 off, get motor on TDC and uhohh the rotor is pointing at #4 not good. Fix that and try again, still no start
but im gettin a puff of smoke, good sign
Finally 4 hrs later, I realise that the choke is opposite on the Super A carb, finally success
Gotta love a 64 year old tractor
Had to vent !
Still wont start !
Had to vent !
