Flail Mower Interchangeable cutters
   / Interchangeable cutters #1
TailDragon
Oak Ridge, TN
Massey-Ferguson 1652 Cab
I did read the long thread on flail mowers ( slept since then) but do not remember if any of the units had interchangeable blades ( hammer/ grass) usable on the same drum. Have read about one on e-bay that seems to offer that ability. Tried searching, may not be using correct wording.
I have a rotary cutter that works fine in open areas but would like a unit shorter for transportation and tighter areas. This would be for my MF 1529 HST. I leave the loader with bucket on to skim the ground before cutting overgrown areas.
   / Interchangeable cutters #2
I know on my Value Leader flail I have the option of either hammer or Y blades and have used both.
Mine came with hammers installed and I ordered the Y blades at same time.
I'm sure other brands have the option as well.
David Sent from my iPad using TractorByNet
The only other one I have read about is the Liberty which looks like the Value Leader with green paint.
Other popular brands seem to require a different drum for rough cut vs fine cut.
Am debating over the hydro shift option as well.
   / Interchangeable cutters #4
I have the hydro shift option, but don't use it :(
The tractor flail is mounted on only has a top cylinder, which I do use. Unfortunately, when doing some rough mowing, I kinda run over the hydro hose on the flail, so I took it off and shifted it to cover my wheel base. Works for me as one side still sticks out enough to get close where needed. If I ever add a 2nd port, I'd likely put it back on.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2010 FREIGHTLINER CASCADIA (A55745)
2010 FREIGHTLINER...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
