Interchangable Auger for Planter
   / Interchangable Auger for Planter #1
jaquetarr
Kerrville TX
PoiwerTrac 2445
I did the search for augers on this forum and found almost the information to answer my question.
Are there other brands of Augers that will fit the PT Planter head. You may recall it is about 3" id on the Head.
In searching posts some have said that Tractor Supply augers will fit, but not in all cases.
Thinking of a 12" and 18" auger to set poles with, needs to go 3' deep.
Looking to see if anyone has found a good sub for the $$$$$ pt auger.
Rgds,
tim
Sorry for the double post, but the first one awarded me a "Server Error"
Thats whay it is blank.
A Thousand Pardons, Oh Noble Ones.
Rgds,tim
   / Interchangable Auger for Planter #3
jaquetarr if there is a tsc store close to you couldn't you take your planter head to the store and ask them to see if it would fit their augers?
I see on the 'Attachments' thread someone made a cart for his PHD. Very good.
From my previous search, Tractor supply seems to be the default auger. With all the other brands, Kubota, JD, ect and all the aftermarket models, it appears that no one has found a duplicate of the Power Trac auger. I did look at a 12" auger from TSC and the size seems close. Like TOY sez, I'll have to drag the head down to TSC to get an exact fit.
I've got to get a privacy fence up so the folks down the street can't see my brick making machines. The auger I have is the 30" one. I just can't find posts that size....
Rgds,
tim
   / Interchangable Auger for Planter #5
The TSC 12" auger fits a little loose. I have one and it works okay I have plans to weld shims on the shaft to tigten it up if I ever get time.
sg
2020 Bell TC-11A Crawler Carrier (A52384)
2020 Bell TC-11A...
FRONTIER AV50H LOT NUMBER 101 (A53084)
FRONTIER AV50H LOT...
UNUSED RAYTREE RMAU2 AUGER (A51248)
UNUSED RAYTREE...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
