INTELLIPANEL OUT OF ORDER ON KUBOTA L3830
   / INTELLIPANEL OUT OF ORDER ON KUBOTA L3830 #1
ARLAN GUFFEY
KUBOTA L3830
INTELLIPANEL WENT BLANK ON MY KUBOTA L3830 AND THE 5 AMP PANEL FUSE IS GOOD. ANY HELP WOULD BE APPRECIATED. THANKS
   / INTELLIPANEL OUT OF ORDER ON KUBOTA L3830 #3
look for a loose connection, do you have power on the panel at all?
   / INTELLIPANEL OUT OF ORDER ON KUBOTA L3830 #4
I have this problem too... it blinked about 3 times and now does not light up at all and of course, tractor won't start. Have checked fuses and repositioned the safety things that could stop it from starting, replaced the battery... and still nothing. Could the intellipanel itself be bad?
What should I check now?
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2018 CATERPILLAR 336FL EXCAVATOR (A51242)
2018 CATERPILLAR...
John Deere 693 Corn Head (A50514)
John Deere 693...
8 Ft Fork Extensions (A50322)
8 Ft Fork...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
