int sickle mower ?
   / int sickle mower ? #1
Sheepdr
fernley,nv
4330 kabota
I am rebuilding a # 24 int. mower started on the sickle bar. Found the pitman strap was broke. I looked at the other one I have and found it had been broke too. Must be a weak point. My question is when I started to put the sections back I found there are thick ones and thin ones. Does the thin ones HAVE to go under the pitman strap? I put. A thick one under it so where the thin ones are its not tight together. Will this cause a problem?
Any other thoughts about these mowers would be greatly appreciated. I have never used one of these before. I have a 6' kuhn but these int mowers are a little different. A book would help if anyone has one.
sheepdr
PHENIX TECH HI POT MACHINE (A50854)
PHENIX TECH HI POT...
2016 Nissan Altima 2.5 Sedan (A48082)
2016 Nissan Altima...
DeWalt Grinder (A50860)
DeWalt Grinder...
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
1500 Gallon Water / Chemical Tank (A50860)
1500 Gallon Water...
2005 WINNEBAGO WORKHORSE W22 RV (A50854)
2005 WINNEBAGO...
