INT 574 3 point hitch will not stay up
   / INT 574 3 point hitch will not stay up #1
schwakc
Pitman, PA
International 574
I own a INT 574 and for some reason the 3 point hitch will not stay up. The 3 point hitch will come up and stay up as long as you hold the handle in the up position, everything else works fine. Can someone please help me? My arm gets tired holding the lever while transporting my 3 point hook up impleaments.
   / INT 574 3 point hitch will not stay up #2
That lever won't stay up on its own. There should be a sliding plastic retainer on the 3-pt lever quadrant with a friction knob that holds the lever up in whatever set position you choose. If you pull the draft control lever all the way up, then the three point should stay up on its own no matter where the 3 point lever is. That's how mine works.
When I let the lever go my three point goes down also. It kind of feels like there is pressure on the lever when I pull up on it. I'm not a hydraulics guy but could I have a bad O ring causing fluid to leak by?
   / INT 574 3 point hitch will not stay up #4
If the control lever wont stay where you place it that's one thing and if the hitch drops without moving the lever that is another.
   / INT 574 3 point hitch will not stay up #5
All 3 pt control levers that I've seen have friction washers to hold lever in place when operators hand is removed. Check for friction washers and tighten them up.
   / INT 574 3 point hitch will not stay up #6
Look were that lever ends ...there is a 3/8 nut (it takes a 9/16 spanner ......tie up that nut a little bit
Thanks guys I will give that a try. Nothing with this tractor has been resolved this quickly I hope it works! Again thank to all!
GRADALL XL3100IV MOBILE EXCAVATOR (A51406)
GRADALL XL3100IV...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2021 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2021 FREIGHTLINER...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
UNUSED FUTURE FT-13 EXCAVATOR (A54756)
UNUSED FUTURE...
2021 CATERPILLAR 279D3 SKID STEER (A52705)
2021 CATERPILLAR...
