INT.424 "pops" through intake
   / INT.424 "pops" through intake #1
LAD1DER
My International 424 with the C-146 gasoline engine has begun to "pop" through the carb/intake. I have determined it to be the #3 cylinder. If I take the plug wire off, the tractor actually runs smoother. I have put a compression gauge on #3, and it reads the same (or close) to the other 3. Any ideas on the cause and fix?
thanks
   / INT.424 "pops" through intake #2
Are you absolutely sure your plug wires are in the proper firing order ?
Otherwise I would suspect a valve problem. Does it sit outside ? My 2444/ c153 had the same problem when I got it. Water had gotten down the stack and rusted a couple of valves up. Had to do a bit of a valve job on it, also had 2 bent pushrods.
Ben
   / INT.424 "pops" through intake #3
Check the timing to make sure that's ok. Otherwise I agree with Ben.
   / INT.424 "pops" through intake #4
Also could be "cross-firing" ie #3 is getting spark from one of the other cylinders. Could happen inside the distributor cap or from wire to wire if the plug wires are routed in a bundle for all or part of the distance from distributor cap to plugs.
Fred
   / INT.424 "pops" through intake #5
May only need a valve adjustment. Besure to check that also before getting to the point of removing the cylinderhead.
   / INT.424 "pops" through intake #6
thanks
If your compression is OK and it is only the #3 cylinder, make sure you have copper wire plug wires and switch the #3 spark plug to the #1 cylinder (and vice versa) to see if your miss moves to #1. Most problems of your type on Farmalls/Internationals are due to too cold a plug or bad spark plug wires. Good luck and let us know. Bobg in VA
   / INT.424 "pops" through intake #7
One other thing, If you are running Champions (probably D16s(?). Change to AC or Autolite plugs (386 Autolites). Makes a world of difference. BobG in VA
   / INT.424 "pops" through intake #8
I agree with the others.. get new AL plugs, new metal core wires.. and a new istrib cap.. carbon tracks can cause spark jumps.
Check timing.
The compression check is a good sign.. if it has the same comp as the others.. then valve wear and ring wear is probably similar.
I might add some MMO to my gass if I thought the valves were a bit sticky..
Soundguy
   / INT.424 "pops" through intake #9
Agree with the others, new cap, rotor, wires, and especially some quality plugs such as autolite. I have had problems also with champion plugs, new right from the box. Only use bosch, and autolite now.
   / INT.424 "pops" through intake #10
Good point on the plug wires and such.
I have found that the only thing I have any luck with Champoin plugs in are small Briggs engines. They seem to do ok in them.
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
Doosan D355-5 Forklift (A55973)
Doosan D355-5...
2018 Caterpillar 287D Compact Track Loader Skid Steer (A56857)
2018 Caterpillar...
2015 Peterbilt 367 (A55973)
2015 Peterbilt 367...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
2023 BOBCAT T770 SKID STEER (A52709)
2023 BOBCAT T770...
