Instrument cluster failure on my 2355
   / Instrument cluster failure on my 2355 #1
Jonny Watson
John Deere 2355
The instrument cluster on my JD 2355 (1989-no cab) would work intermittently usually after running for an hour or so; it has now failed entirely. I have checked fuses and grounds connections. What is next?
Thank you
Jonny Watson
Fall Creek, OR
   / Instrument cluster failure on my 2355 #2
When you state cluster quit do you mean everything quit including lights? When you stated you checked ground connections were you referring to cluster ground?
   / Instrument cluster failure on my 2355 #3
I would check all the connections to the cluster for corrosion.
   / Instrument cluster failure on my 2355 #4
Ive seen some pictures of the plug ends from different tractor instrument clusters on this post. all looks good from the outside, but once there unplugged, the terminals in the connectors are all corroded and nasty.
can you unplug your wiring harness on the cluster and take a look.
Thank you for responding and for your interest.
I don't know where the cluster ground is. I have cleaned up four grounds (1 on the alternator, the 2 battery grounds, and 1 at the fuse bank).
More specifically, the speed hour meter, the coolant gauge, and the fuel gauge are the inopperable instruments. The lights are OK and the small lights that illuminate the instrument cluster function.
   / Instrument cluster failure on my 2355 #6
Hi I just purchased a 2355 and the cluster was not working. The alternator finally died and I replaced it. Lo and behold if the cluster started to work again. It had something to do with the alternator. Hope this helps.
   / Instrument cluster failure on my 2355 #7
German engineering at its finest !! The cluster in 50 and 55 series utility tractors or more specifically the printed circuit board(s) is a common failure part for those machines. Not a very scientific test but normally a failed board on these will be blackened.
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A53422)
2014 Ford F-550...
UNUSED IRANCH 16" EXCAVATOR RAKE (A54757)
UNUSED IRANCH 16"...
2018 Chevrolet Equinox AWD SUV (A53424)
2018 Chevrolet...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
