czechsonofagun
Elite Member
I have this list of to does, but never done it, anything missing?
- use 3/4" black flexible pipe to run the water
- sand under and over the pipe
- plastic orange tape in the ground to indicate the pipe for future digging
- to connect the pipe to the hydrant use 3/4" brass elbow with adapters (if I can actually find one
- install the hydrant, secure it with a piece of rebar to make sure it stays vertical
- turn the water on, check for leaks
- fill the hole with gravel making sure the drain hole is not plugged with dirt or anything
Also planning to have a shot off valve in house.
Any word of experience or suggestion?
