Installing SDR-21 pipe questions
   / Installing SDR-21 pipe questions #1
Nic3456
Sunbury,OH
Na
Going to be install some 2 inch SDR-21 water pipe next week (about 600') and had a few questions.
- anyone have a preferred lube/grease they like to use?
- will the pipe have any flex/give? We need to shift the pipe about 30' over the last 200'
- do you put together the pipe on the surface and then roll in or just pull up the end and attach the new pipe? (I'm going to be about 42"+ deep)
-any other tips? (My builder will be connecting at house and water company will be connecting at meter)
I haven't been able to find any good YouTube videos - if anyone has any recommendations
   / Installing SDR-21 pipe questions #2
I am not sure about the best lube for the pipe. Maybe silicon grease. The manufacturer should have a preferred lube for water. At 2" there will be plenty of flex over 200' of run. Assembly on the ground will be easier. Be careful of over stressing the joints when putting it in the trench.
Others on here may have more experience with this than I. Good luck with the project.
   / Installing SDR-21 pipe questions #3
Get the pipe lube where you get the pipe. Make sure it is food safe
I block the pipe with 2x4 over the trench. Remove board to lower in ditch
Thanks for the tips
   / Installing SDR-21 pipe questions #5
I forget the lettering or numbers on my gasketed water line, but I'm guessing assembly is the same. The place I bought it from supplied the lube. They also supplied granules of bleach. At every section of pipe, a scoop of bleach was put into the end of the pipe. I dug a 2 foot wide trench for my pipe and assembled it in the trench. The big requirement was to make sure the bottom of the trench was smooth. I failed that inspection the first time and had to go back over it again with a shovel to get it perfect. Of course, a snake fell into the trench during the night and surprised me pretty good!!!!
I used a combination of a 2x6 and a pry bar to get it together. You don't want to damage the ends of the pipe, but it takes a bit of effort to get them to slide in to the marks on the pipe.
I had one fairly sharp bend that required a very large cast iron elbow, and a wide gradual bend that I was able to just bend the pipe to install. Be sure the pipe is tight up against the walls of the trench at the bends.
How are you terminating the line? In my case, a cast iron valve was installed with a T was installed to flush out the line. Then I think it was about a dozen 80 pound sacks of concrete where put at the end of the pipe to make sure it didn't pull apart. The concrete was very important, that's another thing they inspected very closely.
After the water was turned on, we waited a day or two, then flushed out the line for at least an hour. Then the water department took a sample, tested it to make sure it was safe to drink. It was. I was told that if I didn't use the bleach, it could take weeks to get all the contaminants flushed out of the pipe.
   / Installing SDR-21 pipe questions #6
I guess I am unsure what the lube and grease is for? IS it for installing the plastic or brass barbed fittings?
What type of SDR 21 pipe are you using? SDR21 is just a reference to its wall thickness. But no indication of what type of pipe?
Assuming you are using PE pipe? the black stuff? IF so, why not just get a 600' roll and have no joints? And if you do have to make a connection, socket-welding is the preferred method as opposed to fittings and clamps. OR are you using a PVC pipe with a SDR of 21??
Also, who decided on the 2". 2" Might be right on, or it might be overkill. I mentioned this earlier in the year, in your other threads.....but did you contact Delco? I assume thats what you have. THere is minimum charges based on meter size. And the bigger the meter, the more the charge. Same goes for tap fee. The potential cost for hooking up a 2" meter/tap is MUCH MUCH more expensive than 3/4 or 1" stuff.
MINIMUM charge for a 1" meter is ~$20
MINIMUM charge for a 1.5" meter is ~$77
MINIMUM charge for a 2" meter is $193
Water lines are one thing you want to make sure you have sized right. You want to have adequate flow/pressure.....but oversizing can cost you ALOT of $$$ month after month.
   / Installing SDR-21 pipe questions #7
Since he asked about lube, I figured he was installing gasketed pipe. The lube is to grease the rubber ring on the female side so you can force the male side of the pipe into it. It's so tight that when under pressure, it wont leak, even when the earth moves and the pipe slides in and out. It is impossible to get them together without using the lube.
   / Installing SDR-21 pipe questions #8
Just wondering why one would want to go to that trouble, and expense, for a residential hookup.
Again, our tap fees are by size. And the price skyrockets exponentially as you increase capacity.
Sizing and installing should not be a seat-of-the-pants, go big or go home, type of thinking. We here the phrase here on TBN all the time..."go bigger than you think you need" Now, planning on building a garage, or installing an electric panel in a garage or buying a tractor....that phrase holds true. But Oversizing your tap just for the **** of it is going to cost you more money, month after month, with no benefit at all.
   / Installing SDR-21 pipe questions #9
I can't answer to the size, or if it has anything to do with meter sizer or not. But for long runs, nothing is better then gasketed pipe. It's more money, but it will outlast any other type of pipe out there because it moves with soil.
   / Installing SDR-21 pipe questions #10
Oversized pipe running from the meter to the project can cost extra for sure, but its a one time expense. If more capacity is needed at a later date your safe. No need to run new pipe. Larger pipe pretty well stops any worries on flow rates or pressure drops. Once you have the pipe ran its easy to adapt it down to the house connection pipe size and the size needed at the water meter. 2 inch pipe does not require a 2 inch meter.
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
2015 Ford Taurus Sedan (A51694)
2015 Ford Taurus...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
2017 Ford F-250 Crew Cab Pickup Truck (A51692)
2017 Ford F-250...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A53426)
2020 INTERNATIONAL...
