Installing Rear Aux Hydraulics on Mahindra
   / Installing Rear Aux Hydraulics on Mahindra #1
scsims
Central, KY
Mahindra 5525
I posted this in the Mahindra forum and it didn't get much action.
I have a new Mahindra 5525 and was wondering if installing remote Aux hydraulic hook ups for the rear is a big job and how much would it cost?
Thanks,
Scott
   / Installing Rear Aux Hydraulics on Mahindra #2
Thanks,
Scott
Here's the hyd remotes on my 5525--dealer installed ($750)
3/8" hydraulic lines, Danoil directional control valves, Pioneer quick disconnects, dealer-fabricated support brackets.
The power beyond port on the FEL valve supplies the hydraulic flow to the remotes.
Installation is not very difficult once you round up the parts.
   / Installing Rear Aux Hydraulics on Mahindra #3
Ray,
Every time I see your post about the dealer installation of those remotes on your 5525, am amazed. That's about the most reasonable installation price I've heard of. What a great deal you got there!
You can install your own (like I did) and it might be a little less expensive than Ray's deal. You can go to Discount Hydraulics or Surplus Center (online sources) to find the valve you want and then buy the components and hose.
OK, but is there a kit? Because I have no clue what I need and how to install it.
   / Installing Rear Aux Hydraulics on Mahindra #5
Thanks,
Scott
Does your tractor have the front loader installed?
Also I sent you a PM.
No my tractor does not have a FEL. What is all needed and are there instructions or do you have to just figure it out?
I'm hoping that there is a kit availble???
   / Installing Rear Aux Hydraulics on Mahindra #8
Yes there is a kit. I think it is in the $600.00 range. Your dealer that sold you the tractor should be able to supply you one.
Are there any internet sources that has them??
2012 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51246)
2012 CATERPILLAR...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
Single Axle Rear Truck Frame (A51692)
Single Axle Rear...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
