Installing New Impeller on Trac Vac 560
   / Installing New Impeller on Trac Vac 560 #1
snpower
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
I used a gear puller to get the old one off; I presume the 'slot' in the impeller has to match up to the 'slot' on the crankshaft for the key to slid in properly? I'm using a mallet and a piece of 2 x4 but not really getting the impeller to move down the shaft - ideas are appreciated !!
   / Installing New Impeller on Trac Vac 560 #2
Now what holds the impeller to the shaft? After you answer this question ... you can look for a burr or other obstruction to the bore. The shaft should be clean, smooth and bright. Same with the bore of the new impeller. That mallet is putting pressure on the other end of the shaft. Can it take the pressure or are you damaging something else.
   / Installing New Impeller on Trac Vac 560 #3
When I replaced my impeller I put it in the oven at 200 degrees for about 45 minutes. It slipped right on.
Pair of Tractor Tires on Rims (A47164)
Pair of Tractor...
RING 2 STARTS HERE @ 9:30 AM (A50459)
RING 2 STARTS HERE...
2018 Kubota RTV-X900 4x4 Utility Cart (A49346)
2018 Kubota...
(APPROX. 130) 32" X 73" EXPANDED METAL (A50459)
(APPROX. 130) 32"...
2004 Ford F-250 4x4 Crew Cab Mechanic Service Truck (A49461)
2004 Ford F-250...
(1) 12ft Livestock Panel (A48837)
(1) 12ft Livestock...
