Installing Koyker K1 Loader on Case IH 235
   / Installing Koyker K1 Loader on Case IH 235 #1
tcam318
1990 Case IH 235
Looking for advice on installing a Koyker K1 loader on a Case IH 235 I recently purchased. My first question is it even possible and if so how easy or hard would the task be?
   / Installing Koyker K1 Loader on Case IH 235 #2
Is the K1 loader designed to fit the 235? The 235 is pretty small. I have a KMW K-95 loader on my 244. The 244 is one generation older and one size larger that your 235. My tractor has an IH Hydraulic adapter package installed to allow a loader to be powered. The IH part number for the package is 1288 102 C92. It is mounted on the left rear of the tractor just under the left rocker arm. It is placed between the hitch housing and the hydraulics system pressure relief valve. It looks like the adapter for a 235 is 1288 348 C91. If you can't get that you will have to custom plumb the loader.
Bill
   / Installing Koyker K1 Loader on Case IH 235 #3
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A53472)
FIRESTONE 9.5L-15...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
LMC G300JD LOT NUMBER 245 (A53084)
LMC G300JD LOT...
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
2023 UNVERFERTH 632 LOT NUMBER 179 (A53084)
2023 UNVERFERTH...
