Installing JD forward lighting kit and rear work lights?
   / Installing JD forward lighting kit and rear work lights? #1
bam747
Palmer Divide in El Paso County, Colorado
John Deere 4720 (2007)
Are these a simple bolt-on and plug-in installation?
I know you have to buy the Light Brush Guard kit to install the front forward lighting kit.
Does the original factory wiring harness already have plug-in pigtails for the forward lighting kit and two (right and left ROPS positions) rear work lights?
At the top level of the configurator it seems to indicate that the forward lighting kit and the rear work lights are not compatible. However, if you bring up the detail page for the rear work lights, it shows both the forward lighting kit and at least a single rear work light installed at the same time. At this level, it seems to say that the forward lighting kit and the rear work lights are only incompatible on the 2305 and 3203 tractors.
Am I correct in assuming that the forward lighting kit and the rear work lights ARE compatible on the 4x20 series tractors?
   / Installing JD forward lighting kit and rear work lights? #2
From my experience with a 790 and a 2320 and rear work lights- the wiring harness will be there someplace and its as simple install (like you said bolt on and plug in)..
good luck
Brian
   / Installing JD forward lighting kit and rear work lights? #3
on my 4320 cab/400 x loader machine they were pre wired and easy to install
simple bolt on and plug in switch
2006 model
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2017 Nissan NV200 Cargo Van (A55788)
2017 Nissan NV200...
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A55788)
2009 International...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2017 Ford F-150 (A53422)
2017 Ford F-150...
