OK, so I'm about to pull the trigger on buying a rear mount snowblower for my
BX2200. My question now is how do I connect the hydraulic chute rotator and probably a hydraulic defector into my tractor's system? Do I tee into the lines going to the FEL joystick and connect these to another 4 way joystick that the snowblower lines will connect to? Does anyone have a reasonably priced place to buy the components (joystick, hoses and couplings) for this? Thanks.
No, you do not tee into anything. Do some research on Open-Center hydraulics and power-beyond. Functions are placed in series and fluid flows continuously until a valve is activated. Fluid flows into the IN port, and out of the PB port to the next valve. The OUT port returns low-pressure fluid (other side of the driven piston) to the sump. The last in line only has an OUT port, since everything returns to sump. On my tractor, the 3pt is last, so it only has an IN port - OUT is internal.
I was faced with the same situation after buying a used snowblower with hydraulic chute controls on CL. I had a power-beyond line and a return plumbed to the back that I used to run my backhoe, but have no valved remotes. I didn't want to install generic remotes onto my tractor - I didn't think I'd have much use for them other than for my blower, and I didn't want to add all that clutter.
I ended up building a dedicated remote setup that runs using the existing PB lines. I only had to add a single line to the tractor (PB to gain 3pt hitch function). The entire remote system is local to the blower, with the valve mounted on an arm that is connected to and moves with the blower. The valve handles are an easy reach, and I am turned around anyway - far easier than operating a manual crank, and I have active flapper control too. The blower/valving is removed as a unit by pulling a couple of hoses, which returns my tractor to it's original PB configuration.
I bought all of my hoses and a few fittings mail-order from Surplus Center - can't beat the pre-made hose prices and the quality was very good. I bought a 10GPM 2-spool valve locally at TST Hydraulics in Merrimack, NH, where I bought the valve and most of my fittings:
Home - TST Hydraulics, Inc
The guys at TST are super-nice and helpful and their prices are good (best valve price I found, including mail order).
JayC
