installing an external tank heater- is it worth it?
   / installing an external tank heater- is it worth it? #1
rmankty
Bronze Member
1948 farmall cub
Hello! I own a Farmall Cub 1948 with C60 engine. I was thinking about buying a magnetic block heater,and someone suggested an external tank heater instead. Are these difficult to install? Are they superior to the magnetic heaters,and worth installing? Thank you for posting your results!
   / installing an external tank heater- is it worth it? #2
We had an external tank Kats 1500 eater on the plow truck in a severe cold climate and it worked wonderful. I would highly suggest that. The magnetic heater was a waste of time for us.
   / installing an external tank heater- is it worth it? #3
A tank heater will heat far better than a magnetic block heater. The best solution is a frost plug heater. They warm the engine from the inside out and you do not lose heat through the hoses.
Magnetic is the worst of the three. I personally do not care for Kats heaters. My preferred brand is Zerostart, the company I work for had terrible failure rates with the Kats.
2017 Ford Expedition SUV (A50324)
2017 Ford...
2018 Club Car Carryall 500 Electric Utility Cart (A51691)
2018 Club Car...
2019 Cadillac XT5 SUV (A50324)
2019 Cadillac XT5...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50323)
2020 Exiss Escape...
Mayrath 10 x 32 Auger (A50514)
Mayrath 10 x 32...
