5030tinkerer
I've installed a total of two pre-hung doors - a newbie at best. The first was installed some eight years ago, the second (an entry door) was installed last night. I must be doing something basic wrong, but can't tell what that could be. Steps I followed:
1. Dry fit the door into the rough opening. Remove the door.
2. Lay a bead of caulk under the threshold. The clock is ticking now.
3. Place the door into the frame.
2. Shim the left or right edge of the door as necessary to ensure the door frame is level.
3. Use shims to get the door relatively snug in the door frame while ensuring that the hinge side is plumb. Tack a few 10d casing nails in somewhat on this edge.
4. Plumb the jamb side of the door using shims. Tack a few casing nails in.
5. Operate the door and find that it sticks on the threshold.
6. Repeat steps 2-5 repeatedly for three hours trying to find a way for the door not to stick.
7. Give up and decide to live with a somewhat sticking door (even though the door is square with the frame).
8. Install a handleset.
9. Work on something else for an hour or so.
10. Note that door is sticking pretty well everywhere now - it takes effort to operate the door is fully out of the frame.
11. Utter words that shouldn't be heard by children (again).
I haven't driven the nails home yet and only have a few sets of shims installed along the jambs, but am at a loss over what to try next. I thought I would have a freely operating door at step 5. I am tempted to just let my framer do this and go, but there are about 25 more doors that will need to be installed and I am trying to do as much myself as possible. Maybe non entry doors are an easier install or I am doing something basic wrong?
