Installing a heat temp oil filled gauge on JD 950
   / Installing a heat temp oil filled gauge on JD 950 #1
bnlake
mansfield,ga
john deere 950
Hi,
I had my john deere 950 rebuild finish and running like a kitten, I wanted to add a heat temp gauge oil filled to the tractor instead of the light indicator, I'm having trouble finding a a fitting to connect the gauge to the block where the temp sensor was removed. I'm guessing right now that the threads on the temp sensor is 14mm (can't get an answer from JD dealer ) The gauge I have found so far is a 1/2 inch npt. Any thoughts as to where to find a fitting or another idea on how to attach an oil filled temp gauge to this tractor ? #2 If I use an adapter on the block do you think the probe will be out far enough?
Thank you
   / Installing a heat temp oil filled gauge on JD 950 #2
Metric Adaptor Kit
View More Images
MSRP: $15.99
Price: $12.00
You Save: $3.99 (25 %)
In Stock
Item Number: PS-METKIT
Manufacturer: Prosport Gauges
Manufacturer Part No: PS-METKIT
Quantity:
Email this page to a friend
Finally, an easy way to install senders for any foreign car. This kit comes with 5 different adaptors all with a 1/8" NPT threaded center.
This Kit includes:
M16x1.5, M14x1.5, M12x1.0, M10x1.0, 1/8"BSP
Only $10.99
Eligible for free First class shipping in the USA.
metric-adaptor-kit -Prosport Gauges M16x1.5, M14x1.5, M12x1.0, M10x1.0, 1/8"BSP
Ray,
I did pickup a set when I bought the gauge , one did seem to fit the opening but, didn't seem to have the right thread pitch, Good news is no leaks.
TYVM
(2) JD Spacers (A50120)
(2) JD Spacers...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52748)
2013 Doyle Dry...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
Terry 12ft Aluminum Jonboat (A50324)
Terry 12ft...
2010 Toyota Corolla LE Sedan (A50324)
2010 Toyota...
Wood Fence Posts (A50121)
Wood Fence Posts...
