Installed Prince HC-PTO-2A Pump
   / Installed Prince HC-PTO-2A Pump #1
Boss 302
Platinum Member
Va.
Kioti RX6010PS Mahindra 3510 Sold (Gonna miss that ole girl)
Installed the Prince HC-PTO-2A pump for my 509 backhoe and prelimanary indications are very positive, It seems to have plenty of power at low RPM's. I'll try it out soon with some hard digging as soon as it stops raining.
   / Installed Prince HC-PTO-2A Pump #2
That pump is a 11.4 GPM pump at 2000 psi, with a max of 2250 psi.
What is the pressure relief set at on your tractor? If it is set at or near 2500 psi, your tractor would have been better.
You had 11 GPM on your tractor. I am not sure why you added that pump.
My unit is self contained and has the reservoir, I much perfer this setup as it keeps everything seperate, I wouldn't want to mix different types of hydraulic fluids especially in a new tractor. I will use the remote hydraulic setup for other things.
2023 CFG QNT45 Mini Excavator (A49461)
2023 CFG QNT45...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2013 INTERNATIONAL...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A49461)
2014 MultiQuip...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
1982 S&S FLATBED (A50854)
1982 S&S FLATBED...
