Installed 3 pt adjuster arms tonight
   / Installed 3 pt adjuster arms tonight #1
RonR
Veteran Member
Kansas
2003 BX2200
I installed my 3 pt adjuster bars tonight. Thanks for those that posted how much to cut to make them fit! I made some bushings, had to drill the bar out to full 1/2 inch so they would fit, then bolted 3/8 bolts through them.
It was great to use! I hooked up a new box blade by pulling the 3/8 push pins (3/8 pin with a ball at one end to help hold it in) and moving the 3 pt arms apart. Hooked up the top link and raised it.
Then walked to the rear of the blade and centered the unit, and reinstalled the push pins.... Easy, Easy, Easy!
A great way to eliminate the sway and it didn't cost too much either!
My weldable chain hooks arrived today, so will weld them to a 1/4" plate and bolt that to the bucket in two places.
Best wishes to all.
Ron, BX2200, FEL, MMM, Tiller, PHD, and box blade.
   / Installed 3 pt adjuster arms tonight #2
If I may ask; what was the cost? I got a quote that was around $200 for the parts.
Cost was about $60 (IIRC)
I ordered it from Carver. Bars and Tubes were sold separately. Pins cost me another couple of bucks, but total it was <$70, with shipping.
UNUSED Roof Thermal Insulation (A53117)
UNUSED Roof...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
CAT 938G Wheel Loader (A47477)
CAT 938G Wheel...
New Holland TS 75 Front Loader Utility Tractor (A53421)
New Holland TS 75...
