Inovative anti-theft ideas?
   / Inovative anti-theft ideas? #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
It is the old addage, if they want something they will figure a way to take it. Wondering what ideas people have come up with to keep their tractor and implements around when you don't have the luxury of a locking barn..
   / Inovative anti-theft ideas? #2
I am curious, too ... especially considering the common keys for tractors.
There are a few similar threads ... if you do a search ... , but I haven't seen anything that appears effective outside of locking your tractor and implements in a garage/barn. Hidden kill-switch?
   / Inovative anti-theft ideas? #3
Take off the wheels and put it on jack stands. :D
Seriously though, there are a couple of thing's you could probably do.
Like WiTel said, a kill switch to disable the ignition/starting system.
You could install a hidden fuel cut off valve.
When I was in the Army all of the vehicles had a chain welded to the floor or steering column. When not in use the chain was looped through the steering wheel and then you put a padlock on it. It prevents you from being able to steer it.
You could get a aftermarket ignition switch with a "real" key. You would have to rewire your switch but it would be better than the one key fit's all ignition switch.
You could install a hard wired alarm system on it. Basically run a wire from your house/barn to the tractor. The wire would be hooked to a 12 volt power source through a relay and when the wire is disconnected from the tractor it set's off a buzzer/siren/alarm in the house.
Let your imagination run wild.
   / Inovative anti-theft ideas? #4
I think about all you can really do is implement some common-sense measures, insure, and pray! I keep mine in a very inaccessable place on the back of the property behind two locked gates and locked to a large tree with a heavy cable. My neighbors watch out for any unusual activity or unknown persons on or around my property or the entire neighborhood since I can't be there as much as I'd like. I've thought about a game camera, but it would have to be infrared (not cheap for a decent one) to have any chance of not being detected and smashed or also stolen. I know that despite almost anything I do, a determined thief could make off with it. So that's where the insurance comes in (inland marine).
   / Inovative anti-theft ideas? #5
On my gas engine in my old IH I would take the battery and rotor home with me every night. The geniuses would try and put a battery in it and start it but not many of them carried a rotor for a late 70's IH 200C gas engine. :D
   / Inovative anti-theft ideas? #6
i lot of people think buddy works real well,certanly after he put his head though a closed car window at the local lumbar yard:rolleyes: nobody wants to take a chanch.also he dosn't make a sound coming up in stalk mode
   / Inovative anti-theft ideas? #7
My old IH does not have a common tractor key switch, it has a unique key.
Sure they can cross over the solenoid and crank it, but with the anti dieseling solenoid and electric fuel pump, it would be a bit difficult to hot wire.
It also spends it's resting time locked in a shed.
   / Inovative anti-theft ideas? #8
Slowrev.. a few gator clip wires and you can almost hotwire anything.
I like the idea of removing the rotor button on the gasser's.. neat trick.. way better than a kill switch that is SUPER easy to bypass.
inthe end.. unless you are standing there with a gun.. someone will get your stuff if they want it.
A horse farm near me just had someone pull off the interstate.. cut the wire fence by the interstate, cut the back fenc e onthe horse farm, and come in and load up horses into a trailer, and a couple tractors from a barn, and high tail it back to the interstate, leaving the fence open and the rest of the horses to get out.
nice people..
Soundguy
   / Inovative anti-theft ideas? #9
Take out the starter relay. On my tractor that takes about 30 seconds as it's located in the fuse panel. With the FEL on the ground + an implement in the back on the ground - if you can't start the tractor to use the hydraulics, it's pretty difficult to move.
   / Inovative anti-theft ideas? #10
JPM -- what is Buddy, anyways? He kind of looks like a bullmastiff but I've never seen a black one.
2001 Terex 760CM Loader Backhoe (A53117)
2001 Terex 760CM...
16ft T/A Flatbed Equipment Trailer (A50322)
16ft T/A Flatbed...
2001 CIRM Bumper Pull Utility Trailer (A53117)
2001 CIRM Bumper...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2020 KUBOTA RTV...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
