Inner tube size
/ Inner tube size #1
POC
Southern Indiana
Mahindra 3215 4x4
I'm tossing around different options to fix my tire, it is a 15-19.5 on the rear of my Mahindra. I've been looking for an inner tube online. I found ONE place that listed a tube for such a size.
I know good an well others sell such a thing, but I can't find it!
What do those numbers indicate and what else do I need to know about my tire/wheel before finding the right tube?
Patrick
/ Inner tube size #2
I typed "15-19.5 inner tube into a search engine and got 19,000 results. There's even some for sale on eBay.
But I saw the pic you posted in another thread, and you just need to find a tire shop that will boot it and install a tube. If they don't have it, they can order it. I have run "booted" tires for years on tractors. It may vary a little, depending on tire size, but rear tractor tires usually only run at 12-15 psi. A good boot and tube will last a long, long time. My 2600 has a rear tire that was booted probably 20 years ago. It still LOOKS bad, but it don't leak.
/ Inner tube size
I got 87,600 results. Unfortunately, only about 5 of those actually places that had that size for sale. Everything else was just about "inner tubes".
I emailed Gempler's and they could special order two different ones. They were both over $100. I'm not interested in paying 1/3 the price of a new tire when it "may or may not" work.
/ Inner tube size
Thanks.
I've already ordered a new tire, go to get it put on tomorrow.
I noticed that they were listed under different headings.
/ Inner tube size #6
. . . I've already ordered a new tire, go to get it put on tomorrow. . .
That's probably the best aproach. But, I would hang onto that old tire. (keep it out of the sunlight, and it will last indefinitely) If ever needed, you could boot it and put in a tube. It might get you out of a bind. Like I said, I've been running a booted and tubed rear tire on my 2600 for years.
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2016 WEILER P385A ASPHALT PAVER (A62129)
2016 WEILER P385A...
LOOK! (A63111)
LOOK! (A63111)
Ford 8210 (A60462)
Ford 8210 (A60462)
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
