injector washers
   / injector washers #1
tmar04
YM 276
how many washers needed, when changing nozzles on YM2500 (3T80 eng). I think, one copper and one fiber(nylon). Is it necessary to change copper washer(seal) on the pre combustion thing? If so, how do you do it? just tap it out, from piston side? I hesitate to 'tap' on anything close to head!! thx.
   / injector washers #2
There is one under the front pre combustion chamber (copper) you have to drive it out from the piston side. There is one (copper) under the rear pre combustion chamber and there is an insulation washer on top of the rear pre combustion chamber.
Danny
   / injector washers
Thanks. Danny. Is it necessary to remove and replace the copper one in the rear pre combustion area? tried to remove with pick device, and no luck. think I will leave it alone and replace the insulating fiber type washers. what do you think?
KENWORTH FLATBED TRUCK (A52706)
KENWORTH FLATBED...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
Ingersoll-Rand Winch (A53117)
Ingersoll-Rand...
2014 Bomag BW900-S50 (A47477)
2014 Bomag...
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
