INJECTOR PUMP TIMING ON MF 480 XTRA.
   / INJECTOR PUMP TIMING ON MF 480 XTRA. #1
scrowoash
Lusaka
Mssey ferguson 480 xtra
Hi All
Does anyone know which number on the injector pump rotor to line up with when setting pump timing on a MF 480 xtra when viewing through the side cover of the injector pump? Otherwise i will have to spill time if i cant get any info.
Many Thanks
Woody.
   / INJECTOR PUMP TIMING ON MF 480 XTRA. #2
Its a CAV/DELPHI DPA pump Right? Its master splined.. only go on 1 way.. NO WAY to spill time one..
YOU CAN put air pressure to a certain outlet & rotate the drive & it will stop turning at # 1,, BUT you have to know which cyl. to put air pressure to OR give me the pump # & I'LL tell you..
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2018 KENWORTH T680...
378658 (A51573)
378658 (A51573)
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
2012 JOHN DEERE 410K BACKHOE (A51246)
2012 JOHN DEERE...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
