Injector Pump HELP
   / Injector Pump HELP #1
rekerkayak
union, MO
Kubota L295DT
My old 78 L295DT ran great. Then I decided to repair 2 fuel leaks at the o-ring seal on the fuel delivery valve. Replaced all 3 o-rings and the copper washers at the barrel as well. NO more leaks, but now, I can't get enough fuel or pressure to the injectors. Plenty of fuel to the valve, but little to none coming out to the line. Bled all the air out of the system getting a little fuel up to the injectors but not enough and it runs like manure.
Is there some trick to reinstalling the delivery valve assembly on this injection pump?? Checked everything and cleaned everything and I am really good at re-assembling now.
Dave in Missouri
Heil V-1722 28Yd Front Loader Garbage Truck Body (A51691)
Heil V-1722 28Yd...
Ford Super Duty 8ft. Truck Bed (A51692)
Ford Super Duty...
12" x 16.5" Kubota RTV-X1140 Tires (A52377)
12" x 16.5" Kubota...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A51572)
2014 Ford F-150...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
