injection pump lube oil change
   / injection pump lube oil change #1
Anonymous Poster
Epic Contributor
Hi
Dad and I are trying to change the injection pump lube oil on his MF1140. When we removed drain plug from pump it seemed like pure fuel ran out, is this correct. The manual said to drain oil . Any comments or advice
thanks
   / injection pump lube oil change #2
Try the heavy truck forum at www.batauto.com. The diesel mechanics might be able to answer that one. Click the forum botton at the top left to get a list.
   / injection pump lube oil change #3
If you are removing the correct plug, that is an indication the drain interval is way too long, or you have a worn injection pump. Drain and fill as recommended, then do it again at 1/2 the recommended hours. If the tractor runs well and still loads the cambox with fuel, just drain and fill at short intervals.
Thanks, It was probably quite a while since it was done. We'll keep an eye on it
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
2011 Jeep Wrangler Unlimited 4x4 SUV (A51694)
2011 Jeep Wrangler...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
2007 Louisville L-3022-32PT 32' Ladder (A53117)
2007 Louisville...
