Injection pump bleeder assembly
/ Injection pump bleeder assembly #1
6sunset6
Veteran Member
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
I have a MF tractor with a Perkins A3.152 Diesel Engine in it. It has a CAV DPA Injection pump. It has 2 Bleeder Assemblies One in the body and one in the cover.
The cover base screw broke off in the cover. I got it out with a left hand drill bit. Came right out and it showed a corrosion stain around half of it. So cracked for a while. The base goes in with a copper washer under it. I got the two assemblies and copper washers from a co, in the UK. The only people with a parts list online.
I have no manual for this pump so my question is should I torque down the base screw, That the one with the copper washer under it. One is 8 mm and the other a 7mm. They are not supposed to come out , only the plug screw that goes in to it loosens to bleed the pump. Or should I use blue locktite and kind of snug them down on the copper washers. There did not appear to be any loctite on them when I took them out.
/ Injection pump bleeder assembly #2
To bad u didn't do a search for me.. I have them..
I don't normally sell parts but if someone is in dire need I'll help..
DO NOT use loc-tite.. Just snug it down.. I think the torque is 125 inch lbs.. if u wanna torque it..
Thank you 125 in # is in the ball park for oily screws that size.
That worked well 2 new bleeder asm and copper washers. Had to loosen 2 injector feeds up on top. cranked till fuel came out closed one cranked a little more then closed the last one and with a little more crank started right up.
I have an electric lift pump on this because I had so much trouble with the mechanical ones. These engines are very common on boats and I had one supplier tell me the fishing guys change the mechanical lift pumps every 2 years . I think , since I do not use this machine much,, I should sell it,, The ignition switch has erratic contacts and the lift pump stops sometimes. actually just this once . But I have noticed I have to bang on the fuel gage to get it off empty . sign of bad contact to me. Or bad grounds .Of course the cracked bleeder did not help at all.
I hired a mechanic once when I was at my wits end to start it and he removed the secondary air filter and stuck gasoline wet rag in the hole. Started right up. But I will save that trick for when I am at my wits end again. Thank you pump guy 125 in # felt just right.
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
Hurricane THB750 Hydraulic Breaker Excavator Attachment (A61572)
Hurricane THB750...
24220 (A56859)
24220 (A56859)
John Deere 4040 Tractor (A64047)
John Deere 4040...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
2018 International HX620 Quint Dump (A62613)
2018 International...
