i see what you mean, i thought you were talking about where the catch is on the rod. I see in the pic that it looks bent on the horizontal part. Im not sure if thats a optical illusion in the pic, i will have to go sheck when i get home. As far a s the pull lever it looks that way but if you bend back away from the tractor that would make the original spring looser, to tighten the original spring up the lever would have to go toward the back of my tractor, thats the way its under tension. Yesterday i was working and oiling the hindges which i think i will take apart today and get the rust out and smear grease in there and put back togeather. The thing works with weight in it, it just wound reset, right because that spring dosent apply enough reaward pressure on the rod to allow it to fall back in the notch on the arc. The rod also will slide to the left and right in the mounts on it so if its bent its not so much to bind it in its mouting holes.
