Info on a BX22
   / Info on a BX22 #1
Anonymous Poster
Epic Contributor
I have been gathering info on a BX22 over the last couple of months and all I have read seems to be nothing but good feedback. Anyway, I have a smaller lot (1 acre) and hope to buy possibly 2 more acres. Is the BX22 too much tractor for just the acre I have now? (There is a wooded area I would like to clear and level and several tree stumps that need removing.) I am new to the tractor market other than the typical garden tractor (I currently have a Craftsman 25HP.) What is the difference between a cat 0 and cat 1 3 pt hitch.
   / Info on a BX22 #2
Nicklas,
The difference between categories is basically size/capacity. Cat 0 uses 5/8" top-link and lift pins, and the spacing of the lift arms is 20". For Cat 1, the pins are 3/4 and 7/8, I think, and the arm spacing is 26". Where you generally see the biggest difference is in lift capacity. I don't know what the specs call for, or if lift capacity is even specified, but Cat 1 will generally lift much heavier implements. From a practical standpoint, it is much easier to find Cat 1 implements than Cat 0 stuff (been there, done that).
Kevin
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
HAY KING RENOVATOR (A52472)
HAY KING RENOVATOR...
HYUNDAI 30D-9 STRAIGHT MAST FORKLIFT (A51246)
HYUNDAI 30D-9...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2015 Jeep Compass Latitude SUV (A50324)
2015 Jeep Compass...
