Inflating tractor tire with water ballast
   / Inflating tractor tire with water ballast #1
GastonGermain
Campbellville, Ontario
Case 885
Rear tire seems under inflated. I have rotated the tire so that the valve stem is at the top. When I try to test for pressure, water runs out of the valve stem. What am I doing wrong?
   / Inflating tractor tire with water ballast #2
You may get a small amount of water from the valve stem in that position. Did you fill the tire yourself?
Thank you powerpace. I did not fill the tire myself. Should I let the water run a bit then try again?
   / Inflating tractor tire with water ballast #5
You're probably doing nothing wrong. Just get a tire gauge designed for tractor tires, which are built to deal with the water. They have a spring that pushes it out when you remove them from the valve stem, so you have to read them while they are attached, or hold the end of it with your finger until you read it.
You should be able to find one at a good hardware store or a tractor supply outlet.
Terry
Thank you Deere Dude. I will try that tomorrow morning and report back.
   / Inflating tractor tire with water ballast #8
sounds like your air is gone and just have liquid left.
just air it up then check her...
   / Inflating tractor tire with water ballast #9
You're in Ontario and have plain water in your tires? Are you sure it's not windshield washer fluid or another liquid that wont freeze?
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A45046)
2019 ALLMAND BROS...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A42744)
Grady-White 17ft...
2009 INTERNATIONAL PAYSTAR 5600I FLATBED CRANE TRK (A45333)
2009 INTERNATIONAL...
2015 LONE STAR UTILITY TRAILER (A45333)
2015 LONE STAR...
2012 DOOSAN G25KW GENERATOR TRAILER (A45046)
2012 DOOSAN G25KW...
2012 Ford F-350 XL (A44501)
2012 Ford F-350 XL...
