ShenandoahJoe
OK, my B7300 isn't big enough to pull a 3-bottom plow or a cultipacker, but he has his moments.
Major failure of legacy equipment (as they say in the computer room). Leaky pipes. 3 inches of hot mud on the floor. 80-gallon water heater needs to be raised up on blocks before it rusts out. Drain is clogged, so less than 700 lbs is not an option.
Pull the tractor up to the basement door, throw a rope around the canister of the water heater about 5 loops, tie to the front-end loader, and up she goes. Slide some blocks underneath, let 'er back down, and wait for the place to dry out. Try that with your JD 4020!
