indoor gasification boiler
   / indoor gasification boiler #1
wlf89
are they bad to smoke the house up
   / indoor gasification boiler #2
Depends on how much draft you have. I have a Tarm Solo 40 in my garage, it smokes a little when I open the door in certain weather conditions. I wouldn't want it in my living room but it doesn't bother me in the garage.
   / indoor gasification boiler #3
I'm currently building a 24X24 garage to eventually hold a boiler from which to pump heat to the houses on the property. I assume there'll be lots of waste heat to keep the garage cozy.
Is there a good website to check out on the topic of sizing?
The plan is to try a year with a box stove first (6" flue), then buy a boiler if we like the wood-heat experience. What size of flue does your Tharm take?
   / indoor gasification boiler #5
I have a eko 60 in my barn and I would never put one in my house. They smoke real bad when you open the door and also very messy with flyash. The biomass boilers have a draft fan that helps .
Rob
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2017 Bomag BMP 8500 Walk-Behind Articulated Tandem Compactor (A51691)
2017 Bomag BMP...
Approximately 250 Traffic Cones (A51573)
Approximately 250...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
2020 CATERPILLAR 120 MOTOR GRADER (A51246)
2020 CATERPILLAR...
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
