Independent PTO
   / Independent PTO #1
BER
Bronze Member
SW. Indiana
MF1235 HST MFWD
Another newbie question: Is the dual stage clutch on a gear tractor the method for obtaining the independent PTO or is this one of more ways to obtain the independent PTO on a geared tractor?
   / Independent PTO #2
A lot of independent ptos are activated by a hydraulic clutch pack.
   / Independent PTO #3
BER there a lot of different types of gear transmissions out there in the tractor market.
This is one area were 2 similar tractors can have different prices because one can have a more or less sophisticated transmission. I can tell you that your best bet is to look at a lot of different machines and ask the dealers a lot of questions. And, of course, test drive the machines to see if they suit your needs.
   / Independent PTO
Thanks for the post. I guess this hyd clutch pack could be engaged/disengaged by different methods. Some might use an electric solenoid and others maybe use a mechanical lever to engage the clutch pack. Would a dual stage clutch also be used with the hyd clutch pack?
   / Independent PTO #5
I used to operate a ferguson 35 and it had a two stage clutch. The first down pressure on it stopped the tractor and a bit more stopped the pto. I have a jd5300 now and it has a lever that engages the clutch with a lever totally separate from the main transmission. I don't care much for the JD system, but it works. I just replaced the pto clutch in mine and found that to engage the clutch they have a throwout bearing that is actually a throwin bearing. I know it is just a problem with my thinking, but I was surprised to see a system set up this way, having to force the fingers of the pressure plate in to engage the pto, thereby having the bearing under load when the pto is being used.
   / Independent PTO #6
Here is a good explanation of a Live, independent and transmission PTO. Your two stage clutch is a live PTO, not an Independent.
PTO Explanation
Hope this helps everyone.
murph
   / Independent PTO #7
All of the hydraulic clutchs packs that I have ever seen were activated by solenoid.
   / Independent PTO #8
BER, I've never heard of a two stage clutch incorporating a clutch pack. The clutch activates a mechanical shaft to drive the PTO, while the shaft is activated by the hydraulic clutch pack on the independent styles. On my Case-IH tractor the independent PTO is activated by a lever which activates a hydraulic valve to send pressure to the clutch pack to activate the PTO. This arrangement allows the PTO to be "feathered" to gently engage the implement. I've never operated a solenoid engaged PTO, so I don't know if it can be gently engaged.
   / Independent PTO #9
</font><font color="blue" class="small">( I've never operated a solenoid engaged PTO, so I don't know if it can be gently engaged. )</font>
They are not very gentle, at least mine is not, so I never start implements much above idle.
But I do like the independant PTO.
   / Independent PTO #10
The IPTO on the MF compacts have a stepped engagement.
2011 Ford F-350 Knapheide Stakebed Truck (A52377)
2011 Ford F-350...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
2008 CHEVROLET C7500 BUCKET TRUCK (A51406)
2008 CHEVROLET...
2014 Ford F-550 Altec AT37G 37FT Bucket Truck (A51692)
2014 Ford F-550...
2023 EAST TEXAS 40FT GOOSENECK TRAILER (A53426)
2023 EAST TEXAS...
