Increasing Horsepower?
   / Increasing Horsepower? #1
Westonium
Chehalem Mountain area, OR
JD 4310
I overclock and mod my PCs.
I tune and mod my cars (all of them).
And now I have a JD 4310 with a Yanmar engine and I'd like to consider reasonable ways to increase the output, say up to 20% higher than rated.
Somebody SOMEWHERE has to have tried this. Anyone?
   / Increasing Horsepower? #2
You might try boosting the ignition /forums/images/graemlins/wink.gif. I have a suspicion those Yanmar engineers knew what they were doing when they designed it.
   / Increasing Horsepower? #3
It might be as simple as larger (flow rate) fuel injectors. I understand the only difference between my Iseki TS1610 (19-20 motor HP) and the Iseki TS1910 (22-23 HP) is the size (flow rate) of the injectors. That's close to a 20% difference. I would think the fuel inj. pump would be large enough since it already by-passes some of the fuel back to the tank.
Bill in CO
   / Increasing Horsepower? #4
Just redline it. Then when she blows u can rebuild her anyway u want......Just kiddin ya. I think at a given RPM your going to get the same HP unless you rebuild your engine and change some ratios. You can increase fuel flow but that would only increase RPM's......Bore it out get bigger pistons, change your crank, cam etc.... And you get more HP.
Kioti uses a turbo charger. I have not looked into how that gives them 20% more HP....
Keep in mind that the rest of your tractor is designed for a given HP. You could overload your PTO or Transmision. Snap!!!!
   / Increasing Horsepower? #5
For most Ag tractors farmers have historically just had the injection pump turned up. If there is a pump rebuilder close by they maybe could do that for you. There are some risks. Too much will probably burn a piston. Just curious but is your tractor weak on power? Most compacts lose traction first. If your tractor is under warranty just don't do it.
   / Increasing Horsepower? #6
I've also heard that some shibaru engines have governor and fuel injector settings a tad higher on units that have only a couple/few hp differences.
Soundguy
</font><font color="blue" class="small">( For most Ag tractors farmers have historically just had the injection pump turned up. If there is a pump rebuilder close by they maybe could do that for you. There are some risks. Too much will probably burn a piston. Just curious but is your tractor weak on power? Most compacts lose traction first. If your tractor is under warranty just don't do it. )</font>
You present a good argument for not doing it... but I'll still consider it.
For Example:
You'd think that those brains at Chevy knew what they were doing, but I can give any stock C5 corvette about 12HP at the wheels using a leatherman and 2 big zip ties (taking one side of the air box off). The intake inlet is way too restrictive. Now, that simple mod isn't 20%, but it is certainly noticeable.
The tractor certainly seems to lack power when cold. It takes a good while for it to build when it is cold outside - and that to me seems odd. Cars usually have excellent HP cold - the air is denser, etc.
Maybe it is more TORQUE that I am looking for.
I do need more traction, but I am already working on that. Specifically, I need chains for dealing with these hills on occasion, and might need fluid fill in the rears.
I wonder if anyone has used this same engine in a turbo-diesel application? Are there turbo-diesel Yanmars?
   / Increasing Horsepower? #8
Yes, some have turbos, but only a few of the larger ones.
Chris
   / Increasing Horsepower? #9
Most diesel hotrodders start with adding fuel or lengthening the duration of the injectors pulse (usually to add fuel and timing.) Adding fuel increases HP & torque until it begins to have breathing problems. So the next step is to make it breath better. Higher flowing filter box and exhaust. This is 2nd hand info from hanging around the dieselstop (Ford) forum.
Warning, messing with diesel fuel/timing can cause increases in the Exhaust Gas Temperatures (EGTs.) High EGTs can burn valves, and on turbocharged engines eat turbin vanes. Diesels under load run hotter than gas engines at the exhaust valves. (I think!)
Another warning! Dieels can runaway and explode. They don't have spark or throttles to shut off. If they are getting air and fuel they will continue to run. Horror stories of diesels with leaking crankcase fumes getting into the intake with no way to limit. As the RPMs increased it spewed more fumes until BOOM.
   / Increasing Horsepower? #10
The injection pump shop I use said they had some JD Yanmar injector pumps come in that the power module in the pumps wasn't up to specs. You might want to have a shop check yours.
Turning the fuel volumn up at the injector pump & torbo charging are the most common ways of increasing hp on diesel tractors. When these things are done it is even more important not to lug the engine. Lugging leads to higher exhaust temperatures & can lead to melted pistons. When we added a turbo to a tractor we installed a Pyrometer that measures exhaust temperatures. Older tractors transmissions & rear ends were over designed & could handle the extra hp. The newer tractors' transmissions & rear ends are designed more closely to the hp of the engine. I don't know how much extra hp they can handle
JOHN DEERE 3032E TRACTOR (A51247)
JOHN DEERE 3032E...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
HEAVY DUTY TRACTOR BRUSH GUARD (A51247)
HEAVY DUTY TRACTOR...
MAHINDRA 6110 TRACTOR (A51247)
MAHINDRA 6110...
2013 Club Car Carryall 252 Electric Utility Cart (A51691)
2013 Club Car...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
