Increased GPH for ULSD
   / Increased GPH for ULSD #1
Chuck_Lind
Mahaffey, Pa.
2000 New Holland TN65 & 1956 John Deere 50
Does anyone notice an increase in GPH (Gallons Per Hour) usage with the ULSD (Ultra Low Sulphur Diesel) fuel being used in tractors?
Last year I really noticed it when using my 6' rotary mower. It seemed like I was using nearly twice the fuel on ULSD compared to the pre-ULSD.
Anyone have the same experience? It's almost llike the USLD doesn't have the "energy" the old diesel fuel had.
   / Increased GPH for ULSD #2
It doesn't. The reduction in sulfur has also reduced the energy content of the fuel. In OTR trucks the average is somewhere between a 2-5% decrease in fuel economy. Using double the fuel sounds really high. Is the tractor running ok, do you notice any decrease in power. Just wondering if there might be another problem there.
   / Increased GPH for ULSD #4
All that gets you in many places is the red dye, it is often the same fuel except the dye is added.:eek:
   / Increased GPH for ULSD #5
The big fuel depo here dies the fuel for the "NON-TAXABLE" off-road stuff.. same fuel for both died or non-died
   / Increased GPH for ULSD #6
My fuel isn't dyed at all! I buy my few gallons; the owner writes the invoice and stamps the invoice with a stamper that states the fuel was sold without dye for farm / non-road use; and, i believe it is 500ppm sulfur. He says sometimes it might be 15ppm sulfur depending on what he can buy at the time.
I can get about 10 - 12 hours out of my 5 gallons (at a time). I just don't use mine hard enough; it only runs at 2900rpms when cutting grass, and that's about as high rpms I run. Doing everything else around the "farm" it can be between 1400 and 2300 rpms.
Joe
Well, not double the amount of fuel used, but it sure seems like it. It appears I have the same power as before, but then again it's hard to tell unless you have the tractor on a dyno.
   / Increased GPH for ULSD #8
I believe the spec lower heating value(LHV) only dropped about 0.5% so if your fuel usage doubled at the same power levels then there's something else wrong.
   / Increased GPH for ULSD #9
Same thing I thought, seems like there might be something else going on there. A slight decrease in fuel economy is to be expected with the ULSD but it sounds rather drastic. Even if you are only talking about 25% more fuel use that is still a excessive amount. I wouldn't expect to see more than a 5% increase in fuel usage using ULSD.
   / Increased GPH for ULSD #10
But you're paying less for it.
but for less money.
Joe
At least you are paying less for it.
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 27ft x 24ft...
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53472)
UNVERFERTH 330 -...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
2006 TerraGator 8104 (A53472)
2006 TerraGator...
