Increase speed
   / Increase speed #1
tractorleo
ohio
craftsman
I am trying to find a way to turn a hydrostatic transmission craftsman riding mower into a racing mower. Any ideas of how to increase the speed are helpful.
   / Increase speed #2
#1 is to increase the speed of the input pulley on the hydrostatic transmission, by either making the drive pulley larger or the driven (transmission) pulley smaller. Note that there is a limit, at which point you haven't enough power to spin things that fast. Also, you may find the limits of the transmission, in a rather rude way. That will get you the biggest gain (short of replacing the transmission with one with higher internal gain.) One other way is to increase the speed of the engine, which is typically limited to 3,600 rpm. There is also a limit to this, but with OHV engines (yours may or may not have it) you can get them to spin a lot faster. You'll need some upgraded internal parts to do so.
I used to know some folks that did tractor pulls with lawn tractors; some cost more than my car.
   / Increase speed #3
Don't know too much about pullers but I didn't think hydrostatic made the best for pulling.
   / Increase speed #4
I aint going to comment on speeding up the transmission. I will tell you that if your Craftsman hydrostatic is a k46 model, you are doomed to a very fast failing transaxle. Those things have a bad rep even when used as intended. You may have better luck if your mower happens to have the k66 transaxle, and it might hold up a little longer if you change out the transaxle pulley for one a little smaller in dia.
As for more info, the k46 transaxle is considered non-serviceable. Replacements start at around $600, but if your handy with tools, you can buy enough parts for a rebuild.
   / Increase speed #5
I think you'll find you want a gear box transmission. I have a backup MTD mower that uses a belt system (like a snow machine) that would also handle an increase in speed. But I think you'll find that the hydro gear box is going to over heat if used for racing. Also it's not as efficient as a geared or belt system. Racing is all about getting the most amount of power to the wheels.
   / Increase speed #7
I'm a big HST fan for tractor usage, but this is probably a case where it's not the right tools for the job. A HST is 15% less efficient in power transmission & racing is all about efficiency of power transmission.
2025 Kivel 48in Forks and Frame Tractor Loader Attachment (A42742)
2025 Kivel 48in...
More info coming soon! (A44572)
More info coming...
DOOSAN G25KW GENERATOR TRAILER (A45046)
DOOSAN G25KW...
2007 KENWORTH T300 SERVICE TRUCK (A45333)
2007 KENWORTH T300...
2008 HEIL PNEUMATIC TRAILER (A45333)
2008 HEIL...
2019 CAT 272D2 (A42021)
2019 CAT 272D2...
